Soutwest 733 díra a dekomprese
františek dobrota
http://www.novinky.cz/zahranicni/amerik ... -mice.html
http://twitpic.com/a9vk8
SOUTHWEST AIRLINES INFORMATION REGARDING FLIGHT 2294
Scheduled Nashville-Baltimore Flight Diverts to West Virginia
DALLAS, TX—July 13, 2009—Southwest Airlines confirms Flight 2294, the 4:05 pm Eastern scheduled departure from Nashville to Baltimore/Washington diverted to Yeager Airport in Charleston, W. Va at approximately 5:10 pm Eastern today after a cabin depressurization. All 126 passengers and crew of five onboard landed safely and are awaiting a replacement aircraft in Charleston that will take them to Baltimore/Washington International Airport later this evening.
The aircraft cabin depressurized approximately 30 minutes into the flight, activating the passengers’ onboard oxygen masks throughout the cabin. Medical personnel in Charleston assessed passengers and no injuries are reported. Southwest Airlines is sending its maintenance personnel to Charleston to assess the aircraft, and the airline will work with the NTSB to determine the cause of the depressurization. According to initial crew reports, the depressurization appears to be related to a small-sized hole located approximately mid-cabin, near the top of the aircraft.
There is no responsible way to speculate as to a cause at this point. We have safety procedures in place, and they were followed in this instance to get all passengers and crew safely on the ground. Reports we have are that our passengers were calm and that our Pilots and Flight Attendants did a great job getting the aircraft on the ground safely.
In an abundance of caution, we have initiatied an inspection of all 737-300s tonight. We expect only minimal impact to tomorrow's schedule until all of those inspections are complete.
františek dobrota
creyman
Re: Soutwest 733 díra a dekomprese
Historie se opakuje -
http://www.novinky.cz/zahranicni/amerik ... l?ref=boxF
Všechna letadla B737 prý na víkend uzemnili.
Lucky
u stareho Boeinga maji zase o cem premyslet
Naprostá pohoda jako obvykle u Southwest
Je dekomprese, ve stropě díra, ale pán se v pohodě prochází pod dírou jako by to byla otevřený střešní ventilační poklop v busu, někdo si díru ve stropě fotí, nikdo nemá nasazenou masku:
http://www.ceskenoviny.cz/svet/zpravy/s ... etu/618278
jane
Tak ono je trochu zbytecne mit nasazenou masku, kdyz v ni uz neni zadny kyslikGlobík píše:Naprostá pohoda jako obvykle u SouthwestJe dekomprese, ve stropě díra, ale pán se v pohodě prochází pod dírou jako by to byla otevřený střešní ventilační poklop v busu, někdo si díru ve stropě fotí, nikdo nemá nasazenou masku:
Aha. Díky té díře?jane píše:Tak ono je trochu zbytecne mit nasazenou masku, kdyz v ni uz neni zadny kyslikGlobík píše:Naprostá pohoda jako obvykle u SouthwestJe dekomprese, ve stropě díra, ale pán se v pohodě prochází pod dírou jako by to byla otevřený střešní ventilační poklop v busu, někdo si díru ve stropě fotí, nikdo nemá nasazenou masku:
Spis diky tomu, ze v masce je chemicky vyvijeny kyslik jen na par minut. Ono se v takovem pripade stejne sklesava do dychatelnych vysek. Piloti maji samozrejme kysliku o hodne vic, taky myslim neni chemicky vyvijeny, ale skladovany v tlakovych nadobach.
Aha. To jsem netušil. Tak jsem zase za vola.
Nicméně:
Pokud jsou ty snímky z rychlého klesání, je podivné, že ti lidé stojí/chodí. Pokud byl stroj již na zemi, je zase divné, že ostatní sedí.
Nicméně:
gr09
Vedel jsem, ze nevydrzi dlouho, ale netusil jsem, jak se vyrabi, zajimave cteni: http://en.wikipedia.org/wiki/Chemical_oxygen_generator
Kazdopadne predpokladam, ze nesel hned ze smeru na pristani a ze po sklesani na bezpecnou (resp. postupy danou) vysku letel chvili v konstantni vysce, nez provedl potrebne ukony (+ spalil palivo do MLW?)
jane
To bude urcite pak z letu v te nizsi hladine. Pri klesani pri dekompresi by to urcite neustaliGlobík píše:Aha. To jsem netušil. Tak jsem zase za vola.
Nicméně:
Nemyslim si, tohle neni zasadna vecGlobík píše:Tak jsem zase za vola.
