American Airlines - trafo
flashmaster
Příspěvek od flashmaster »
Zdravím, blokl jsem si v letadle místo se zásuvkou. Chci si vzít notebook s tímhle: http://www.alfacomp.cz/php/product.php? ... 10BR000WQ4
Pustí mě s tím do letadla?
díky za radu:)
Re: American Airlines - trafo
Podle mě není trafo na seznamu zakázaných věcí na palubu. Jsi si ale jistý, že to potřebuješ? Že je ve "Tvém" letadle 12V a ne 110V?
Lanbub
Příspěvek od Lanbub »
Zde jsou veškerá info:
Powerports
On some aircraft, your seat may be equipped with a DC power outlet, using a "cigarette lighter" style outlet delivering 15 volts of direct current (and up to 75 watts). We do not provide adapters, but they are available for purchase on the Duty Free cart internationally where we offer duty free. On select B737 & B757 aircraft, your seat may be equipped with an AC power outlet, using an outlet similar to a standard U.S. style home outlet. These AC outlets provide 110 volts of power. On most aircraft*, a power outlet is available at each seat in First and Business class, as well as selected rows in the Coach cabin. On select B737 & 757 aircraft, there is an outlet available on each row.
Outlets may be used to operate laptop computers, CD/DVD players, charging cell phones and other devices with a maximum 75-watt capacity. Outlets are located on your seat console, or mounted to the seat frame below your seat cushion. Look for the "lightning bolt" symbol on the overhead bin rows containing powerport-equipped seats. Splitter or Y adaptor cords may not be used. Only one device is allowed per outlet. System power is available when the green light on the outlet is illuminated. For detailed powerport locations by aircraft type, visit the Our Planes section on AA.com.
*Powerports are offered on Boeing 777, 767, 737, Boeing MD80, and B757 aircraft. Use of powerports is permitted only when the aircraft is above 10,000 feet in altitude and the flight attendant announces that personal electronic devices are allowed. The use of powerports is at your own risk. American is not responsible for loss of data or damage to personal hardware or software.
flashmaster
Re: Aamerican Airlines - trafo
Měla by tam být "cigaretová zásuvka" jako v autě. Tj. na to trafo co je pod odkazem výše. Ja se raději ptám, protože mi to připadá jako podezřela krabička a byl bych nerad, kdyby mi ji zabavili :( budu ji potřebovat v autě.
